Activity Forums Avid Media Composer Modifying Emulsion Codes for Film Lists
  • Modifying Emulsion Codes for Film Lists
    Posted by Cecily Rhett on September 6, 2006 at 6:22 pm
    Am trying to prep for a DI out of Xpress Pro 4.6. Shot 16mm, telecined to dvcam, captured on a full composer system to reverse pulldown, cut at 24. Issue is that in telecine reader couldn’t read new Eastman Kodak Emulsion Codes for 7217 and produced a “?” in the Emulsion Code column. I want to modify the keycode to add the correct emulsion code and do not know if it is safe to do on the “modify clip” level. I could also modify the pull/cut lists to reflect the Emulsion Code but do not know the best way to do it.
    Advice?
    Cecily Rhett replied 19 years, 11 months ago 2 Members · 2 Replies
  • Michael Phillips
    September 7, 2006 at 2:18 am
    You can change it directly in the bin for each KN Start value. You will be notified with a terrifying warning, but go ahead and say yes. Repeat for each one and regenerate your list.
    Michael
    anything 24fps
  • Cecily Rhett
    September 12, 2006 at 2:55 pm
    Dear Michael,
    Thank you! (They are terrifying messages..)
