Activity Forums Maxon Cinema 4D modifying an electrical wire without distorting the shape
  • modifying an electrical wire without distorting the shape
    Posted by Scott Green on February 23, 2009 at 4:45 pm
    I modeled an electrical wire (with both the inner metal threads and the outer rubber casing) using straight cylinders. I used 3 of the bend modifiers to bend the wire in different directions and give it a more realistic appearance.
    But it wasn’t brilliant, it was difficult to adjust the bends without it affecting everything else and distorting the shape of the wire. I was wondering if maybe there’s a way to attach it to maybe a spline so that I can more the points accurately and position the wire exactly how I want it without distorting the shape of the wire too much?
    Would my other option be to learn how to use bones perhaps?
    What would be the best way so that I had full control over the positioning of my wire?
    https://www.splurj.com
    Brian Jones replied 17 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Brian Jones
    February 23, 2009 at 6:42 pm
    use a spline with the cross-section shape of your wire then extrude that along a spline with an ExtrudeNurb
  • Scott Green
    February 23, 2009 at 8:57 pm
    Would it be possible to use a twist on the wires sticking out at the end too using this method?
    Like they appear inside a real wire?
    Thanks for your response, I’ll give this a bash, cheers.
  • Brian Jones
    February 23, 2009 at 11:34 pm
    earth to my brain….. sorry, I meant SweepNurb not ExtrudeNurb
  • Adam Trachtenberg
    February 23, 2009 at 11:48 pm
    Yes, the sweep nurbs object has a spline graph for twist, so you can add more at the end.
  • Scott Green
    February 24, 2009 at 10:07 am
    That’s great guys, thanks very much.
  • Scott Green
    February 24, 2009 at 10:20 am
    I’m afraid I’m stuck again guys, if you look at this image:
    https://z.about.com/d/create/1/0/D/s/-/-/BasicWire2.jpg
    Can I apply the individual inner copper wires (with a twist at the end), as well as the outer plastic casing all to a single spline?
    I imagine this will have to be done using 2 splines (one for the copper wire and one for the plastic casing) but wouldn’t that mean I’d have to position each spline in exactly the same position individually? I also want to make the copper wire stick out at the end of the casing like in the photo?
  • Scott Green
    February 24, 2009 at 11:00 am
    Ok, I’ve figured out how to do the inner wires and the plastic casing, but they are both on separate splines, can they both be on one spline that I can move to affect both the inner and outer of the wire?
  • Brian Jones
    February 24, 2009 at 4:44 pm
    probably the simplest thing to do is to use the spline for one of your sweeps then use Instances of the spline for the other sweeps. It’s really only one spline that way so when you edit it they all change.
