Activity Forums Adobe Premiere Pro Modify text of title layer in xml
  • Modify text of title layer in xml
    Posted by Praveen Kulk on May 6, 2023 at 4:35 pm
    I have bulk of texts to be replaced in premier pro sequence, it has a title layer which has dummy text. And i exported the sequence to xml. In xml there is an element which has that dummy text as value. But changing it won’t reflect in premier pro. Any other way?
    Praveen Kulk replied 3 years, 3 months ago 2 Members · 2 Replies
  • Shahid shahan
    May 6, 2023 at 7:16 pm
    Hey kulk,
    You could try using the “Find and Replace” feature within Premiere Pro to quickly replace all instances of the dummy text in your sequence. This can be found under the “Edit” menu.
    Another option is to use Premiere Pro’s “Essential Graphics” panel to create a text template that can be easily updated with new text. This allows you to make changes to the text without having to go through the process of replacing it manually each time.
    Shahan.
  • Praveen Kulk
    May 7, 2023 at 2:46 am
    I have already created title from essential graphics tab. I am creating a python script which will replace the text and create separate xml for all texts. i am not using extendscript because i need to make a video speed change to bulk off clips which can’t be done with extendscript that’s why doing python. In xml file there is one element called value which seems to be base64 encoded. It has all the information regarding text but can’t encode it back properly
