Activity Forums Apple Final Cut Pro Legacy modify speed error
  • Don Greening
    January 6, 2006 at 6:51 am
    There must be clips on either side of the one you want to make the speed change on that would be changed or altered, time or length-wise if your spped change command was carried out. For example, if you’re trying to slow down a clip it’s going to be longer than the original, so make sure there’s enough room between clips to allow for the extra length.
    – Don
  • Arnie Schlissel
    January 6, 2006 at 5:28 pm
    Also, if you have a transition on one or both ends of that clip, you might get that type of error. You can remove the tranny, apply the speed change & then add a new tranny.
    Arnie
    https://www.arniepix.com
