Activity › Forums › Adobe After Effects Expressions › Modify sourceRectAtTime Expression to Ignore a Specific Character
Posted by Quest Rogers on October 3, 2017 at 5:52 pmHello.
I’m wondering if someone can help me figure if it’s possible to modify the expression below to ignore a specific character. This expression is applied to a rectangle’s path size so that when text is typed a box increasing the visibility of the text is created behind it to the specific length of the line of text. When a comma is typed the box extends lower than I’d like and makes the text look as if it’s not perfectly centered in the box. Basically I want the expression to resize to the length of the text without factoring any commas.
If anyone has any ideas I would appreciate any help.
Thanks.
x=thisComp.layer("Title").sourceRectAtTime().width+18;
y=thisComp.layer("Title").sourceRectAtTime().height+12;
[x,y]Keith Hopkin replied 6 years, 4 months ago 5 Members · 10 Replies -
Paul Connors
October 5, 2017 at 4:54 pmThis is a GREAT question. I have this exact issue from time to time and have just settled with it looking out of sorts. I would love to know the answer.
Quest Rogers
November 13, 2017 at 7:15 pmSadly, no. I knew it was a bit of a long shot and that no one would likely reply. I searched pretty vigorously for an automated solution to this and just couldn’t find one.
Dan Ebberts
November 13, 2017 at 9:55 pmThere are a couple of hacks you can try.
Put an expression like this in your text layer’s Source Text property:
if (time < 0) value.replace(/,/g,””) else value
That will remove the commas at times less than zero. Then in your shape expression, you can get the sourceRect() at a negative time to get the height you want and at the current time to get the width:
L = thisComp.layer(“Text”);
h = L.sourceRectAtTime(-1,false).height;
w = L.sourceRectAtTime(time,false).width;
etc….An alternative would be to have a hidden text layer with an expression that gets its text from the main text layer and removes the commas:
thisComp.layer(“Text”).text.sourceText.value.replace(/,/g,””)
Then your shape expression would again use two soureRect() references:
h = thisComp.layer(“Text Copy”).sourceRectAtTime(time,false).height;
w = thisComp.layer(“Text”).sourceRectAtTime(time,false).width;Dan
Quest Rogers
November 14, 2017 at 7:24 pmHi Dan!
This is helpful. I’ll try this out in the next couple of days.
The only issue is that I don’t want the commas removed. My job has decided to use commas for certain punctuation in lower thirds. I’m trying to see if there’s a way for the expression on the shape to parse the source text for commas and ignore them. This would keep the text layer looking centered in the shape instead of the shape getting larger at the bottom to accommodate the comma descending below everything. What do you think? Is this possible?
Quest Rogers
November 14, 2017 at 9:33 pmOh ok.
I tried the alternative method you mentioned that seems to work well for me.
thisComp.layer("Title").text.sourceText.value.replace(/,/g,"")
This was applied to the source text of the duplicate text layer.h = thisComp.layer("Title Copy").sourceRectAtTime(time,false).height+13;
w = thisComp.layer("Title").sourceRectAtTime(time,false).width+17;
[w,h]This was applied to the Size of the Rectangle Path Shape layer.
x=content("Rectangle 1").content("Rectangle Path 1").size[0];
y=content("Rectangle 1").content("Rectangle Path 1").size[1];
[x/2,y/2]
And this was applied to the Position of the Rectangle Path Shape layer.Many thanks for your help with this Dan! Much appreciated.
Hans Terlouw
July 17, 2019 at 12:09 pmThis works perfect. I only want to add some more punctuation that needs to be excluded in the duplicate text layer. These are the following
J
_What would the expression be for the source text in the duplicate text layer?
Quest Rogers
July 17, 2019 at 12:26 pmLike this. You need to separate what you want excluded with |\ and then the character.
thisComp.layer("Title").text.sourceText.value.replace(/,|\(|\)|\J|\_/g,"") -
Keith Hopkin
April 29, 2020 at 4:30 amI just came up with a decent workaround (might’ve been mentioned here).
Make a test layer containing the characters with descenders like ‘pyl,.’ maybe add some CAPS in there as well. Then just reference the height of this textbox for any manipulations
Where the layer “get-text-box-sizes” is just the text layer that you could hide.
// workaround to get a height with descenders so all boxes are consistent
s=thisComp.layer(“get-text-box-sizes”);
defaultTextboxHeight = s.sourceRectAtTime().height;Keith
twitter.com/keithhopkin
ArtworkNotAvailable.com
ThatSongSoundsLike.com
facebook.com/keith.a.hopkin
