Activity Forums Adobe After Effects Expressions Modify linear expression to use fourth and fifth keyframes of a property
  • Modify linear expression to use fourth and fifth keyframes of a property
    Posted by David Cabestany on May 4, 2022 at 5:57 pm
    I use this expression structure a lot:
    r=transform.yPosition;
    k1=transform.yPosition.key(1).value;
    k2=transform.yPosition.key(2).value;
    ease(r,k1,k2,0,22)
    Today I’m trying to to the same but instead of using keyframes 1 and 2 y need to use the 4th and 5th, so I wrote this instead:
    f=thisComp.layer(“50MM”).cameraOption.zoom;
    k1=thisComp.layer(“50MM”).cameraOption.zoom.key(4).value;
    k2=thisComp.layer(“50MM”).cameraOption.zoom.key(5).value;
    linear(f,k1,k2,100,0);
    But when I play the animation the value before the third keyframe is 100, and I need it to be 0 up until the moment it hits the 4th keyframe.
    When the 4th keyframe is reached the animation happens as expected.
    Thanks in advance for your help.
    David Cabestany replied 4 years, 4 months ago 2 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    May 4, 2022 at 7:01 pm
    Try this:
    f=thisComp.layer("50MM").cameraOption.zoom;
    k1=f.key(4).value;
    k2=f.key(5).value;
    time < f.key(4).time ? 0 : linear(f,k1,k2,100,0);
  • David Cabestany
    May 5, 2022 at 3:44 pm
    Works great, thanks a lot Dan.
  • David Cabestany
    May 6, 2022 at 1:19 am
    Hey Dan, sorry to be a pest but I think I jumped the gun too fast, the expression is not working and instead is returning the error f.key is not a function.
    I tried making f different properties, such as position or rotation but nothing worked.
    I was looking at a different expression when I said this one worked. My bad.
  • Dan Ebberts
    May 6, 2022 at 4:37 am
    Hmm… It works for me. The only way I can make it fail with that message is to do this:
    f=thisComp.layer("50MM").cameraOption;
    instaed of this:
    Maybe you could post a screen shot.
  • David Cabestany
    May 10, 2022 at 3:50 pm
    I’m trying to use it on a different comp with different properties, writing this:
    f=thisComp.layer(“cam ctrl”).transform.position[2];
    k1=f.key(2).value[2];
    k2=f.key(3).value[2];
    time < f.key(2).time ? 0 : linear(f,k1,k2,0,58);
  • Dan Ebberts
    May 10, 2022 at 4:17 pm
    I’d suggest trying it this way:
    f=thisComp.layer("cam ctrl").transform.position;
    time < f.key(2).time ? 0 : linear(f[2],k1,k2,0,58);
  • David Cabestany
    May 10, 2022 at 10:04 pm
    that did the trick. thanks a lot.
    is the last part before the linear expression a new format for using an if/else statement?
  • Dan Ebberts
    May 10, 2022 at 10:20 pm
    Not new (it’s the JavaScript conditional operator), but I like it because you can use it on a single line with minimal punctuation.
  • David Cabestany
    May 11, 2022 at 5:15 pm
    Looks like I have some catch-up reading to do then.
