Activity › Forums › Adobe Premiere Pro › Modify audio on import
  • Modify audio on import
    Posted by Warren Morningstar on January 26, 2011 at 6:55 pm
    OK, I know there is a way to do this, because I’ve done it before in previous versions, but I can’t find it in the help files.
    When I bring my clips into CS5, I want to modify the audio to split the stereo track into two mono tracks (I always shot with a nats mic on one channel and my primary mic on the other). There used to be a setting somewhere so that the clips were modified upon import, rather than having to go through and manually modify them.
    Tim Kolb replied 15 years, 8 months ago 3 Members · 4 Replies
  • Andrew Devis
    January 26, 2011 at 7:44 pm
    Check the tutorials I just put one up on this.
    Andrew
    … because it’s all about stories …
  • Tim Kolb
    January 26, 2011 at 9:21 pm
    It’s a preference…audio “source channel mapping”
    TimK,
    Director, Consultant
    Kolb Productions,
  • Warren Morningstar
    January 26, 2011 at 11:27 pm
    Thanks Tim. Appreciate all the advice you freely give on this forum.
  • Tim Kolb
    January 27, 2011 at 6:19 pm
    [Warren Morningstar] “Thanks Tim. Appreciate all the advice you freely give on this forum.”
    Well…thanks for the thanks.
    The heads you see up top are definitely the brain trust around here. I’m not around as much as I once was…
    Andrew’s tutorial portfolio for PPro is extensive here at the Cow and he does a nice job of subdividing topics to keep the tutes relatively short and focused, so that’s a resource that shouldn’t be taken for granted.
    So…lots of help freely given around here…by many…
    TimK,
    Kolb Productions,
