Activity Forums Maxon Cinema 4D modify a mesh (for beginners)
  • modify a mesh (for beginners)
    Posted by Paul Rijkaard on November 23, 2014 at 8:58 pm
    Hi
    I am a beginner C4D user.
    I have imported a mesh .obj file that I generated via autodesk 123D Catch. The mesh represents a section of a face.
    The mesh is an irregular shape and I would like to make holes in it as if it’s surface has been perforated. How do I start doing this in C4D?
    many thanks in advance
    Brian Jones replied 11 years, 10 months ago 3 Members · 3 Replies
  • Paul Rijkaard
    November 23, 2014 at 9:00 pm
    Sorry, just to add, that it is important that circular holes are generated allowing light to shine through etc.
  • Giacomo Bompan
    November 24, 2014 at 2:54 pm
    hi there,
    I’d suggest you use the Boole object to “dig” holes onto surfaces. It basically subtracts one volume from another.
    You can find tons of tutorials on how to use it
    Cheers!
  • Brian Jones
    November 24, 2014 at 3:43 pm
    you are looking for the Boole object. You put your object and the object (or objects in a Connect object for more than one) into the Boole and you can cut the one from the other. There are limits to what you can do with a Boole but it is a good start. Boole will cut (Subtract)/Add/remove (Without) but the default is Subtract.
