Activity › Forums › Apple Final Cut Pro Legacy › Modest fix for bad chroma key?
  • Modest fix for bad chroma key?
    Posted by Josh Figatner on September 2, 2009 at 3:03 am
    Hello everyone,
    I have some pre-keyed short videos that are less than ideal and I’m wondering if there is anything I can do to help it look better.
    The issue is spill. The key itself is good, but there’s a noticeable green spill halo present, saturating hair and clothes a bit. The producer of these segments neglected to add enough spill suppressor. Is there any way to even minimally recreate this tool after a key has already been applied? I’m working on FCP 6 with access to Motion and Color if need be.
    thank you,
    Josh
    Alan Okey replied 17 years ago 3 Members · 3 Replies
  • Rafael Amador
    September 2, 2009 at 3:51 am
    FC have an Spill Suppression Filter to be used after the keyer.
    Try it.
    rafael
    http://www.nagavideo.com
  • Alan Okey
    September 2, 2009 at 9:58 pm
    Try using FCP’s 3-way CC. Limit the effect to the range of the green spill, then desaturate to taste.
  • Alan Okey
    September 2, 2009 at 10:27 pm
    Be careful – FCP’s spill suppressor can product some nasty results, sometimes visible as a dark ring around keys. You’re better off rolling your own spill suppressor using the 3-way CC and limiting the effect.
