Activity › Forums › Maxon Cinema 4D › Modelling Problem [beginner]
  • Modelling Problem [beginner]
    Posted by Mohamed Abdallah on October 13, 2018 at 8:55 pm
    Hello ☺ I’m a beginner in c4d and I’m making my very first project when I came into this modelling problem which I couldn’t solve
    when I apply a texture I find some polygons are darker than others like in this photo
    and it’s getting worse when I use subdivision surface
    all the polygons are set normals and the projection of the texture is set to cubic
    is there any way to fix this
    Steve Bentley replied 7 years, 11 months ago 3 Members · 2 Replies
  • Brian Jones
    October 14, 2018 at 12:48 am
    can’t tell without seeing the file (though maybe somebody can)
  • Steve Bentley
    October 22, 2018 at 8:56 am
    To me that looks like polys or points from the inside are projecting through the outer surface. And they may have different lighting on them because their normals may be facing the opposite way the normals on the surface are (so you are technically seeing the inside while still on the outside.
