Activity Forums Maxon Cinema 4D Modelling a guitar body
  • Modelling a guitar body
    Posted by Matt Royle on March 29, 2020 at 4:43 pm
    Hi all
    I’m modelling a guitar body, which will eventually be used to create gcode for a CNC router. I have created the plans in illustrator, and am using extrude nurbs to create the body from the paths. I’m able to create things like the neck pocket and pickup cavities using booleans, but wanted to get a bit of advice on how to contour the outer edge of the body. I can’t use caps because the inner edge of the contour is not a consistent distance from the outer edge of the body.
    What would be the best workflow for this? I’ve tried manually adjusting in point mode, but it just felt too imprecise. Can I use a spline to add vertex points to the extruded object? How do you think I should be going about this?
    Any advice or guidance would be much appreciated.
    Cheers
    Matt
    Matt Royle replied 6 years, 5 months ago 2 Members · 2 Replies
  • Frank Feijen
    March 30, 2020 at 10:50 am
    I think I’d use a loft for that.
    But I’m sure there are multiple approaches possible.
  • Matt Royle
    March 30, 2020 at 11:16 am
    Thanks Frank, I’ll try that out and let you know how I get on :]
