Activity › Forums › Maxon Cinema 4D › Modeling Question
  • Modeling Question
    Posted by Pravin Chottera on January 22, 2015 at 6:05 am
    Hi all,
    I can’t seem to figure out how to model the object below.
    I could try doing some hypernurbs modeling, but is there a way to do it with deformers?
    As always, appreciate everyones help. Thanks all!
    Brian Jones replied 11 years, 8 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    January 24, 2015 at 4:51 am
    If you’re using R16 I would use the new “preserve curvature” function of the Slide Tool. This video should be self explanatory, except when sliding the edge loops you need to hold down Ctrl/Cmnd while dragging to create new loops.
    https://youtu.be/G0mExQTTpyU
    If you’re not using R16 I would probably create a cube primitive with sufficient Y subdivisions and make it editable. Then I’d create a spline curve to use as a guide and use spline snapping to move the front points to the desired shape.
  • Adam Trachtenberg
    January 24, 2015 at 4:40 pm
    Here’s a version of the video tut with better production values. 🙂
    https://youtu.be/fNhDhlPoheA
  • Brian Jones
    January 24, 2015 at 10:00 pm
    Soft Selection in scale is good too.
