Activity Forums Maxon Cinema 4D Modeling Bed Covers
  • Modeling Bed Covers
    Posted by Neal Barenblat on June 8, 2010 at 10:46 pm
    I’m on a pretty tight deadline and need to create some beds for a client. They have bedspread that tuck underneath and into the frame (basically as if you made your bed), and I’m not sure how to go about this and get the most realistic look. I’ve been fooling around with cloth, but I’m just not sure what to do with it in order to get that “tucking” effect.
    Randy Johnson replied 16 years, 2 months ago 2 Members · 1 Reply
  • Randy Johnson
    June 9, 2010 at 10:11 am
    Model a cube (with cloth tag) over a collider cube(mattress) then use the dressOmatic to shrink the cloth cube into place.
    You need to make sure you have enough geometry to get the curves in the cover as well try to keep the polygons as uniform in size as possible and avoid TRI polys.
    /Randy
