Activity Forums Maxon Cinema 4D Modeling and Shading A Ribbon with Arrowhead
  • Modeling and Shading A Ribbon with Arrowhead
    Posted by Dan Fredley on September 1, 2010 at 4:07 pm
    Here is a movie reference to my question:
    https://dl.dropbox.com/u/234493/CreativeCow/A049_C006_0830P0_SmartMeter_v002_1_H264.mov
    There are several things wrong with this shot, but the two I want to focus on are the modeling and shading issues with the arrowhead.
    1) If you step through the shot, you can see a distinct line between the arrowhead and the ribbon–how do I connect these smoothly?
    2) Also, you can see the arrowhead has the same material as the ribbon, but the shading is going in a direction perpendicular to the ribbon and it is also condensed. How do I change it so the shading is continuous between the two pieces?
    The ribbon is a sweep nurbs object and the arrowhead is a spline wrap.
    Thanks.
    Dan Fredley
    Dan Fredley replied 15 years, 12 months ago 3 Members · 3 Replies
