Activity Forums Maxon Cinema 4D modeling and animating a pie chart
  • modeling and animating a pie chart
    Posted by Andrew Wilson on February 13, 2012 at 4:17 pm
    I need to create and animate an pie chart. I’ve started by creating a cylinder object and making it editable but I can’t figure out how to cut it into 4 sections.
    Basically, it would have 4 sections that are slightly blown apart from each other and then one section grows while another shrinks and the other 2 stay the same.
    I figured starting with the cylinder object would be the easiest so I don’t have to model the 4 sections into a perfect circle shape.
    I remember something about turning on point animation to make the sections change size but I’ll probably need a reminder on where to find that as well.
    Thanks.
    Andrew Wilson
    WestView Digital Video & Design
    http://www.westviewdigital.com
    Emmet Reddy replied 14 years, 7 months ago 2 Members · 2 Replies
