Activity Forums Maxon Cinema 4D model slicing
  • model slicing
    Posted by Michael Rosen on January 27, 2010 at 11:34 pm
    I’m looking to create an animation (in c4d r11.5) that assembles an object by stacking slices of it.
    This is to illustrate the lithographic modeling process.
    I’ve ben playing with mograph to create a stack of slices, then booleans to get them into the right design….but when I then turn then into editable objects, I can’t control the movement with mograph any more.(and caps, from the booleans, are created as a separate object from the slices.
    Is there some plugin that will create horizontal slices of a model (similar to the “destruction” plugin….but actually more simple)?
    Any ideas would be very much appreciated.
    Thanks in advance.
    Tim Shetz replied 16 years, 7 months ago 3 Members · 4 Replies
  • Simon Hutchinson
    February 11, 2010 at 10:15 am
    How about using the model in a boole and animating a stack of slices into it so that the boole only reveals the part of the slices that fall into the models shape?
    “Democracy cannot consist solely of elections that are nearly always fictitious and managed by rich landowners and professional politicians”
    Che Guevara
  • Michael Rosen
    February 11, 2010 at 10:24 pm
    thank you. Is there a way to get the slices to stay the correct shape from the boole as the move away from the boole shape. (eg animating the mograph mod to bring slices together, but keep them looking correct as they come in?)
    Thanks again
  • Michael Rosen
    February 14, 2010 at 1:06 am
    I figured it our and I thought I’d let everyone know:
    1st create the object mesh you’d like to slice.
    2nd, use mograph cloner to make slices using planes or thin cubes.
    3rd, use a boole to cut the slices to the exact final-state you’d like them to be in.
    4th, turn the cloner/bool object into a editable object (press c).
    Then create a new cloner and add the mesh slices to it and increase the number of clones to the number of slices.
    now you can do all types of neat tricks with mograph to the slices!!!
    The trick for me was realizing that multiple objects could go into a cloner.
    Thanks all.
    Michael
  • Tim Shetz
    February 15, 2010 at 7:44 pm
    Michael –
    Thanks for sharing your discovery. So often people on the forum find solutions and never come back to share them either because they are too busy using what they discovered, or they just forget… so thanks again for taking the time!
    Tim
