  • Posted by Bob Tanner on September 20, 2010 at 10:47 pm
    I need to convert files from a JVC HD Camera, (.Mod) and I don’t have the JVC video camera, only the .Mod files. I have problem converting .Mod to any other format. I’m using Mpeg StreamClip every time the audio is off-sync. I put the exported files into FCP and the audio off-sync is in a lot of places and if you move one place in sync, the rest is still out of sync… Its around 70 files that need to joint into one..
    I’v read a lot online and I’v tried nearly everything, I’v also tried inserting the frame rate before I exported it on Mpeg StreamClip…
    Any Ideas, Thanks,
    Zevie
    Michael Sacci replied 16 years ago 2 Members · 1 Reply
  • Michael Sacci
    September 20, 2010 at 11:32 pm
    have you tried using compressor. and what are you settings you are trying.
