Activity Forums Apple Final Cut Pro Legacy .MOD Problems
  • Posted by Gully Moore on August 31, 2010 at 4:30 pm
    Hello,
    I have a Canon Legria FS19 which records .MOD and .MOI files.
    To edit them in FCP I need to export them as DV Clips in MPEG Streamclip, but the problem is that they are all in the wrong order! There are so many clips and it would be impossible to order them properly.
    I know this isn’t really a FCP question, but I’m a bit stuck!
    Gully Moore replied 16 years ago 2 Members · 2 Replies
  • Michael Sacci
    August 31, 2010 at 6:10 pm
    What do you mean “in the wrong order?” if you are not changing the name why would the order change unless you are viewing them by date, and if so change it to name.
  • Gully Moore
    September 1, 2010 at 12:25 pm
    No I worked it out, the naming of the clips put them in the wrong order. But if you view it by date then it works okay.
