Activity Forums Adobe After Effects mochila tracking is not going well
  • mochila tracking is not going well
    Posted by Jesper Pedersen on May 21, 2020 at 10:04 am
    Hi everyone, I´ve spent more than 10 hours on this issue, I´ve seen lots of videos, I have read dozens of posts, I´m a Mocha newbie but that being said, I find the following problem very peculiar – I enclose 5 pictures as documentation,
    1 The tracking in Mocha is perfect(trans, scale, rotate) I turn it off and return to the AE interface and press Create Track data and choose “Layer 1”
    2 I import the video “Fairy dust” which is suppose to follow the path of the main movie and mask out the part of the movie that isnt relevant I the part of the “Fairy dust” movie that is relevant.
    3 Here I have repositioned the “Fairy dust” mask above the princess.
    4 In the Mocha effects panel I choose the “transform” option and then layer expor to “Fairy dust” the 5 dots appear on the face of the princess – and follows the movement of her face, so everything seems perfect so far!
    5 But when i press “Apply export” – the masked Fairy dust object moves away from its position, and I cannot in any way get it back! In this case, it fairy dust masked movie is seen to the left of the princess-
    Question: How to fix this?? thank you very much in advance…
    Graham Quince replied 6 years, 4 months ago 2 Members · 1 Reply
