Activity Forums Adobe After Effects MochaImport script + tutorial
  • MochaImport script + tutorial
    Posted by Mathias Möhl on May 27, 2009 at 3:42 pm
    I have created an After Effects script that simplifies the usage of the Mocha Tracker with After Effects. If you use Mocha for After Effects(or if you didn’t so far because it seemed to be too complicated) you should take a look at it.
    A free download as well as a video tutorial can be found at
    https://aextensions.blogspot.com/2009/05/mochaimport.html
    The script works with both Mocha version 1 which is included in After Effects CS4 and with version 2.
    Mathias Möhl replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
