Activity › Forums › Adobe After Effects › Mocha troubles!!! Cant see video.
  • Mocha troubles!!! Cant see video.
    Posted by Jorge Rosado on October 17, 2011 at 3:38 am
    I’m trying to do some tracking in Mocha for AFX which I’ve done before but for some reason now when I import my footage I cant see the image. Here’s a screen shot of the problem.
    Thanks in advance!
    Jorge Rosado replied 14 years, 11 months ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    October 17, 2011 at 8:32 am
    Try another video and if that works then take a look at the CODEC used for the problem footage. Then take the necessary action.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia.
  • Sean Mullen
    October 17, 2011 at 3:10 pm
    Hi Jorge,
    I’ve run in to this in the past. If you are using After Effects CS4, it seems that the version of Mocha that comes bundled with it doesn’t like certain codecs like ProRes. I’ve had good luck with converting to the Animation codec – just for tracking purposes.
    Sean Mullen
    Rampant Design Tools
  • Jorge Rosado
    October 17, 2011 at 4:21 pm
    Thanks! Changing the codec worked!
