Activity Forums Adobe After Effects Mocha Tracking Data Export Won’t Change
  • Mocha Tracking Data Export Won’t Change
    Posted by Jerry Tran on August 9, 2012 at 2:07 pm
    So I know how to track and export the data. Im having a problem, I dont know whether its because I am using CS4, but when I export the tracking data and I paste it onto my null object, it puts the tracking data but when I look at the data, the position, scale, etc, they are the same value and shows that it does not change.
    EX:
    See the values 778.0 , 469.5 , that value stays the same no matter what, I tried
    copying and pasting the clipboard and doesnt put the different values but keeps it all at the
    same value. Why is it not copying it in right??
    Cyrus Dowlatshahi replied 13 years, 11 months ago 3 Members · 3 Replies
  • Ross Shain
    August 13, 2012 at 6:09 pm
    Try deleting all the anchor point keyframes. Do you see anything happen?
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Cyrus Dowlatshahi
    October 19, 2012 at 8:22 pm
    I have this same problem… though I don’t have any anchor point keyframes.
    I copy/pasted ‘After Effects Corner Pin [supports motion blur]
    Running CS6…
  • Cyrus Dowlatshahi
    October 19, 2012 at 8:32 pm
    I got it. I had created an ‘exclusion layer’ and had THAT layer selected when I clicked export… and so it was exporting garbage essentially.
