Activity › Forums › Apple Final Cut Pro Legacy › Mocha track into fcp not working
  • Mocha track into fcp not working
    Posted by David Schuurman on April 8, 2011 at 2:44 am
    Hi folks,
    nice to be here. long time reader!
    I have just started using Mocha for FCP and I have been tracking splines really well and inserting the mocha logo in to check how it looks and it all looks great.
    My problem is when I export tracking data and bring it into FCP and paste the attributes to the graphic I want to use it’s all wonky. sometimes its in a totally different section of the image, sometimes its just skewed improperly.
    This is really getting me down because I get so excited when my project looks so good in Mocha but I cant do anything with it because the final step in FCP messes it up!
    Is there any advice you can give? any steps I may be missing? suggestions?
    I would really appreciate some insight here.
    THanks so much.
    David
    Christopher Grimm replied 14 years, 1 month ago 3 Members · 3 Replies
  • Christopher Grimm
    July 31, 2012 at 3:08 pm
    Hi. I’m about to start cutting a 54 minute video down to around 8 minutes in FCP. Unfortunately there’s a smudge on the middle of the lens and I cannot reshoot.
    After Effects would be fairly laborious but may be my only option. I read that Mocha can do it better/faster.
    Advice greatly appreciated!
    I’d rather a full bottle in front of me than a full frontal labotomy…
  • Ross Shain
    August 2, 2012 at 4:51 pm
    You might want to check out mocha Pro, which has a Remove Module that can assist in removing unwanted objects. It analyzes shots and can use the before/after frames to replace the object.
    A few videos that may help:
    https://www.youtube.com/watch?v=ByeG6ukvqRE
    Or
    https://youtu.be/wGrKh76CmQU
    Good luck,
    Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Christopher Grimm
    August 3, 2012 at 1:45 pm
    I have Mocha Pro.
    Will give it a whirl!
    Thanks for the advice.
