Activity Forums Adobe After Effects mocha stabilization
  • mocha stabilization
    Posted by Bipop Upreti on August 5, 2009 at 8:22 pm
    hi i have a situation here. Im trying to stabilize a footage with a pan shot. it doesnt have too much perspective change. I shot it on a tripod but there are still some jitery movements and little bumps. anyways i tracked it in mocha using three different tracks because the shot has a long range of movment and the tracks would go outside of the shot. so i pasted the track into AE into three nulls. the first null contains trak info from 1-90 frames. 2nd 91-200 and 3rd 201-499. I parented the first null to second and second to third creating a a master null with position and rotation info. Is there anyway i can extract the positional info from the master null and paste it into my shot so i can stabilize it?
    Ross Shain replied 15 years, 3 months ago 6 Members · 10 Replies
  • 10 Replies
  • Moira Elefson
    August 5, 2009 at 8:48 pm
    Why can’t you just parent the footage to the master layer? Do you have to copy/paste?
  • Bipop Upreti
    August 6, 2009 at 12:38 am
    that doesnt stabilize the video, it just moves and rotates the video according to the null data. I need to do the opposite to stabilize and inorder to do that i need the keyframes, but i dont have complette keyframes in my master null becaue they are divided in three nulls with seperate positional data.
    do you understand now? its kinda confusing to explain
  • Jim Dodson
    August 6, 2009 at 12:56 am
    Take a look here:
    https://forums.creativecow.net/thread/2/962101#962115
    Basically you want to pickwhip the position of your video to the anchor point of the master null
    Then pickwhip the anchor point of your video to the position of the master null.
    Then pickwhip the rotation of your video to the rotation of the master null — then edit that rotation expression by adding “*-1” without those quotes…
    Jim Dodson
    8 Core Intel — Mac – OSX
  • Bipop Upreti
    August 6, 2009 at 5:57 am
    Hi i understand where you are going with pickwhiping but my master null has only 1/3rd of the position keyframes, 2/3 of the data are in other nulls. so if i dont have complete keyframes how can i pickwhip?
    here is a list of what i have in my project right now
    1st null. Position and rotation keyframes from frame 1-91
    2nd null. position and rotation data from frame 92-201
    3rd nul. position and rotation data from 202-499
    layer 2 is parented to layer 1
    layer 3 is parented to layer 2
    therefore Layer 3 is the master null that moves throughout the shot because of parenting but has only 1/3 of the keyframes.
    now How would i go about stabilizng the shot using these information?
  • Chris Buttacoli
    August 6, 2009 at 3:53 pm
    I’m sure there is an expression you could use to find the real world space and orientation of the master null, but I will have to leave that up to the experts. Also, an expression can be based on conditions like frame number, which would allow you to choose which null to use to claim data from.
    But try this. Make the master null and footage layer 3D layers, and create a new camera. Move to the last frame of the comp and parent the camera to the master null. Re-frame the camera appropriately by adjusting the z-rotation and zoom level. The footage is now stabalized.
    But is this what you were looking to do? Or are you just trying to smooth your pan?
    BTW – Correct me if I’m wrong, but you don’t need to seperate the track into three nulls. You can simply adjust the spline in Mocha as needed and it will continue to maintain the tracking data.
  • Jim Dodson
    August 6, 2009 at 5:04 pm
    So null 3 is your master
    try my suggestion using null 3 as your master
    Jim Dodson
  • Bipop Upreti
    August 6, 2009 at 5:31 pm
    thanks i didnt know u can change the spline i thought it would mess up track
  • Chris Buttacoli
    August 7, 2009 at 2:33 am
    Jim, the reason you can’t use your method is due to the parenting operation. Because Null 3 is parented, it has no position data or scale data or rotation data prior to its own keyframes at frame 202.
  • Eddy Bergman
    June 21, 2011 at 5:57 pm
    I realize this is an old thread but for anyone that has trouble stabilizing a long panning shot, I worked out a methode just using the AE built in tracker. It’s really easy. Here’s a link to my tutorial blog which explains it all:
    https://aftereffectstutorials.blog.com/2011/06/19/stabilize_a_long_pan_in_ae/
  • Ross Shain
    June 21, 2011 at 7:20 pm
    There is actually a very cool technique for dealing with panning shots in mocha. You “unlink” the layer shape from the track data.
    This way the shape stays in place and creates an offset track. As pixels come into the shape it will track them rather than follow select pixels.
    This is covered in this video tutorial:
    https://www.imagineersystems.com/videos?tagFilter=tracking+pans&sortBy=Newest
    Alternately, you can stop the track and move the shape. You should not have to join multiple tracks to accomplish the task.
    Best,
    Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
