Activity Forums Adobe After Effects Mocha Screen Replacement
  • Mocha Screen Replacement
    Posted by Sujay Bhosale on July 25, 2019 at 9:03 am
    I am tracking phone display in mocha. Display has curved corners and notch.
    Display is tracking perfectly. But I have issues with the replaced screen. Replaced screen doesn’t have curves.
    I used insert module.
    I used different method too. I made pre-comp of replaced image and fit to comp size and applied tracking data. and then also created AE masks and copied it to Replaced screen (to get the same shape as phone’s curve) But it has got weird shape.
    What is the solution for this?
    Sujay Bhosale replied 7 years, 1 month ago 4 Members · 9 Replies
  • 9 Replies
  • Richard Garabedain
    July 25, 2019 at 4:45 pm
    you precomposed incorrectly..or a layer is 2d where it needs to be 3d inside the compt…or try continuous rasterize
  • Sujay Bhosale
    July 25, 2019 at 6:34 pm
    How do I make the corners and notch fit perfectly?
  • Cassius Marques
    July 25, 2019 at 7:02 pm
    mocha took into consideration the proportions of your image. That workflow is different than the usual with AE’s tracker, so you don’t have to scale to comp size, just precomp the image (leaving attributes) and apply the masking there.
    Cassius Marques
    http://www.zapfilmes.com
  • Martin Brennand
    July 25, 2019 at 11:37 pm
    If you’re using the insert module, just create a mask that matches the curve of the phone and link it to the tracking data.
    You can then either use it as your foreground mask in the Insert module or use the resulting mask as a matte back in After Effects.
    Martin Brennand | Product Manager | Mocha – Boris FX (Imagineer Systems)
  • Sujay Bhosale
    July 26, 2019 at 7:47 am
    How do I create mask that matches phone curve? I just clicked on ‘Use all foreground layers’ and it worked. Is that fine?
    And I am not able to import video into insert module. I tried may different formats.
  • Martin Brennand
    July 29, 2019 at 4:18 am
    If you’re using the plugin, just import the screen insert via the “Insert Layer” option.
    See “Rendering Insert Layers” under the After Effects plugin section:
    https://borisfx.com/support/documentation/mocha/6.0.0/#_applying_the_mocha_plugin_for_adobe_after_effects
  • Sujay Bhosale
    July 29, 2019 at 4:37 am
    I am able to insert image in the insert layer but not videos.
  • Martin Brennand
    July 29, 2019 at 4:44 am
    You mean you can’t use the layers from the timeline in After Effects as videos?
    Don’t try importing them externally from disk, use the “Insert Layer” option in the plugin interface.
  • Sujay Bhosale
    July 29, 2019 at 4:54 am
    Thank you for all the solutions. It’s working fine now.
