Activity Forums Adobe After Effects Mocha pro remove module have no effects.
  • Mocha pro remove module have no effects.
    Posted by Assaf Goldlust on September 8, 2017 at 2:48 pm
    im trying to a remove an object from a video. i tracked the backgorund and the object. but when i press render in the remove module nothing happens.
    with that said its important to note that only happens when im trying to get mocha figure out what to remove. when im creating a cleanplate and use photoshop its works fine. if any body knows whats the problem. i can really use help here
    Assaf Goldlust replied 8 years, 11 months ago 2 Members · 4 Replies
  • Ross Shain
    September 8, 2017 at 4:18 pm
    Very difficult to say without seeing the project. Maybe an obvious question but “are there definitely clean frames within the shot”?
    The key to getting a good remove in Mocha Pro is having a good background planar track and there are usable temporal clean areas. If the foreground object that you are removing is passing in front of multiple planar areas, each area needs to be its own track layer.
    You might want to share some images OR submit a support case to have someone look at the issue.
    https://borisfx.com/support/open-a-case/
    Good luck.
    Ross Shain
    Boris FX / Imagineer Systems
    https://borisfx.com/products/mocha/
  • Assaf Goldlust
    September 18, 2017 at 7:01 pm
    sorry for the delay. i followed what you said and added multiple layers for the diffrent part planes in the background.
    it made some progress but still far from looking usable.
    i video cuptured the project so you can look for yourself
    https://www.youtube.com/watch?v=4OX-tfsRjbc&feature=youtu.be
  • Ross Shain
    September 21, 2017 at 3:50 pm
    Looking at your project, it looks like you need to create some clean frames using the clean plate module and a paint package like Photoshop.
    It does not appear that there is enough motion in the shot to get a remove, since the clean areas do not actually exist in the shot. Mocha uses temporal frames to find clean areas and replace, but if the shot does not contain a clean frame, the artist will have to feed it at least one clean plate frame.
    This link will point you to a few videos showing the Mocha Pro Remove + Clean Plate workflow:
    https://borisfx.com/videos/?tags=feature:Clean%20Plate&search=
    Hope this helps.
    Ross Shain
  • Assaf Goldlust
    September 23, 2017 at 9:34 am
    tnx, i will look into it
