Activity Forums Adobe After Effects Mocha Pro Mesh Tracker headaches!
  • Mocha Pro Mesh Tracker headaches!
    Posted by Josh Mannis on April 22, 2024 at 9:30 pm
    My friends,I’m in Mocha Pro in After Effects. I’m trying to use the mesh tracker to track in a little patch to cover the edge of a character’s prosthetic nose. I signed an NDA so I can’t post anything here unfortunately, but I’m sure if seeing the nose would actually help that much. Here was my process:
    Masking Tab
    > Draw mask
    > Set Uniform grid
    > Track itStabilize Tab
    > hit mesh warp
    > up top, expand planar surface
    Make the patch in PS
    Import to AE as footage
    > Merge layers
    > Copy Mocha from tracked layer
    > Paste to patch layer
    > Module renders / drop down renders / warp stabilize
    > Mate / apply matte
    I have a hunch that the issue is somewhere between the stabilize tab step and the point when I get back to AE, but I can’t pinpoint it. Also, the tutorial I was following has their reference frame as frame 1 – mine is later because the focus is better – could that be the issue?
    Thanks!!!
    -Josh
    After Effects 2024
    3 GHz 10-Core Intel Xeon W
    Radeon Pro Vega 64 16 GB
    28 GB 2666 MHz DDR4
    Josh Mannis replied 2 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
