Activity › Forums › Adobe After Effects › Mocha Pro – Matte Clips
Posted by Riccardo Sinti on May 16, 2014 at 4:59 pmI’m trying to import a matte clip to use instead of splines.
Everytime i import an mov (8bit 256 greys) I get a dialog that says mov must be converted to 8bit grey scale to use as matte clip.
When i go to clip module all i see is black.
Any advice on using mate clips?Riccardo Sinti replied 12 years, 4 months ago 2 Members · 4 Replies -
Riccardo Sinti
May 18, 2014 at 12:03 pmFirst I tried prores out of AE6.
Then I tried lossless 265 greys 8bit.
I also tried a jpeg sequence.
Mocha Pro always indicated that the clip would have to be converted to 8bit greyscale. There is a checkbox in the clip module to convert to 8bit so I checked that anyway.
Nothing happens.
I haven’t been able to find much more than a mention in the Mocha doc that you can import a matte clip to replace splines on a layer.
I haven’t seen any tutorials that use matte clips.
Anyone see any out there?
Thanks! -
Ross Shain
May 19, 2014 at 5:01 pmThe key to importing an external matte clips is to create a mocha layer and make the shape cover the entire image area, then select the layer properties and insert a Matte Clip. mocha will read the matte and you will know it is working if you see the matte in the overlays.
Hope this helps.
Ross Shain
Imagineer Systems
http://www.imagineersystems.com -
Riccardo Sinti
May 19, 2014 at 5:31 pmWell, I wasn’t covering the entire image with a spline to make the layer, so I did that but still the matte clip does not show up after I import.
When I go to the clip module the name of the matte I imported is in the drop down but when selected all I see is black.
Is there a particular codec that is preferred?
Is there a tutorial out there that utilizes this feature so I can see it in action?
