Activity Forums Adobe After Effects mocha Pro installed but its menu missing in after effects cs4
  • mocha Pro installed but its menu missing in after effects cs4
    Posted by Bobby Singer on February 10, 2015 at 5:47 am
    I just installed mocha Pro but not able to access ” mocha for after effects” menu in after effects under its animation menu? somebody plz help me
    Jim Scott replied 11 years, 6 months ago 2 Members · 1 Reply
  • Jim Scott
    February 10, 2015 at 3:29 pm
    Mocha Pro is stand-alone only. You would do your tracking in Mocha Pro and then export the tracking data to use in AE. If you were expecting “track in Mocha AE” in the animation menu you are thinking of a different product.
    There is Mocha AE CS6, which came bundled with CS6, and then there was Mocha AE v3, which was compatible with CS4 and had even greater functionality, but it was a separate product purchase from Imagineer. The current version is included with AE CC. But in all cases Mocha Pro is stand-alone.
    Hope this helps.
