Activity Forums Adobe After Effects Mocha Pro in After Effects – remove module issue (No active layers??)
  • Mocha Pro in After Effects – remove module issue (No active layers??)
    Posted by Josh Mannis on February 26, 2024 at 11:57 pm
    Hi –
    I’m having trouble trying to remove an object from a shot – using the remove module in Mocha Pro, in After Effects. I think I’m following the tutorials properly: 1. track the object to be removed, 2. track an object that moves in front of it, 3. track the background, 4. make a clean plate in photoshop, and 5. back to Mocha.
    The object to be removed still appears where it was, and when I try to render a frame I get this alert:
    “Unable to replace layer pixels: no active layers found behind the layer”
    I signed an NDA so I can’t show the clip unfortunately. Does anyone out there have any experience with this?
    Thanks in advance!
    -Josh
    Eric Santiago replied 2 years, 6 months ago 2 Members · 3 Replies
  • Eric Santiago
    February 28, 2024 at 12:30 am
    I tried the same tutorial I think (man on street), and this is the response I got from Boris support:
    It sounds like something might be wrong with the background layer – It could be that it’s not tracked at a nearby frame, that not stacked behind the foreground layer (being removed), or maybe not marked for processing (with the cog icon). Can you quickly double-check all these things. If none of these help, can you relay me your AE project and, ideally, the clip being referenced (that you are removing from the cleanplate)?
    I manage to remove what I can with a lot of messing around but no where as easy as that tutorial shows 😛
  • Josh Mannis
    February 28, 2024 at 9:38 pm
    Thanks Eric! Seems that the original background track was the issue – the area getting tracked was not underneath the object being removed. I think that’s what it meant by “no active layers”?
  • Eric Santiago
    February 28, 2024 at 11:47 pm
    I would need to try that tutorial again.
    I have a few projects that require it.
