Activity Forums Adobe After Effects Mocha Pro… Export best quality???
  • Mocha Pro… Export best quality???
    Posted by Kevin Obrien on February 11, 2014 at 5:03 am
    I’m new to Mocha Pro… I brought in a lossless clip (Quicktime/PNG), tracked & stabilized it and used the Autofill feature to fill in the black edges…
    I’m unclear about how to export the finished work back out in lossless format again.
    I understand exporting tracking data, etc for use in AE… but I can’t find much to clarify the rendering/exporting options.
    Anybody familiar with this?
    thanks
    Ross Shain replied 12 years, 7 months ago 2 Members · 1 Reply
  • Ross Shain
    February 17, 2014 at 7:50 pm
    mocha Pro always renders uncompressed internally. It is up to the user to decide how you want to “export” the rendered clip.
    When you render in mocha Pro, it automatically by default will render to your “Results” folder.
    You could take your rendered image sequence from there OR Use the File>Export Rendered Clips command to export to various options, such as a Quicktime format of choice.
    Hope this helps.
    -Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
