Mocha Pro / AE – Mocha Mask question
Howdy,
Here is my problem, I follow the steps needed to use Mocha Mask from Mocha to AE, it works fine when I use an X-spline mask. but when I use a B-spline mask it goes all wonky, meaning the first frame lines up nicely but every mask point after goes in it’s own direction.
I was wondering if I am missing a step or if it’s not possible to use B-spline with the Mocha mask import option.
Thank you for your time.
