Activity › Forums › Adobe After Effects › Mocha layout
  • Mocha layout
    Posted by John Nelson on November 18, 2022 at 7:30 pm
    Using AE CS4 on a Mac Mini 2014 w/Safari 10.12.6
    Recently opened Mocha to stabilize some video. The layout is way larger than the monitor; Samsung 32″. Can’t seem to drag it down to fit. Didn’t find anything in the ‘view’ menu to correct the problem.
    Appreciate all thoughts.
    Thanks.
    Mads Nybo jørgensen replied 3 years, 10 months ago 2 Members · 3 Replies
    November 18, 2022 at 7:52 pm
    Hey John,
    What version of Mocha are you using?
    Haven’t quite found it on my Mac Mini, but on my Windows PC I can change screen resolution and font size – not perfect, but may do the trick.
    atb
  • John Nelson
    November 18, 2022 at 11:34 pm
    Thanks Mads,
    Version 1.2.2. checked my Samsung monitor and it’s set for the Mac Mini. There isn’t any way to adjust the layout in Mocha preferences or the view menu.
    November 18, 2022 at 11:46 pm
    Hey John,
    Thank you – as mentioned, on windows you can make a lot of changes to the monitor set-up. Although, if you go too large, you’ll need a large magnifying glass to read the text…
    Just checked over on the BorisFX forum and there is a suggestion made back in ’08 by JP (great guy who was with Imagineer from the beginning), which is to delete your preference file:
    https://forum.borisfx.com/t/cant-get-mochaae-to-fit-macbook-pro-screen/736
    The other one is to maximise the Mocha window, but I guess that you’ve already tried that?
