Activity Forums Adobe After Effects Mocha for AE Issues
  • Mocha for AE Issues
    Posted by Kevin Johnson on December 24, 2014 at 4:45 pm
    2014.1 AE on PC
    1920x1080i clip in 1080 AE comp. Send to Mocha. The surface and adjusttrack zoom window isn’t representative of the area that I am trying. For example, if I’m trying to find the exact corner of an iphone (white bezel and black screen area), the zoom window is nowhere close to there, just showing a blurry white mess. Any sort of fix?
    I’ve never been able to use a DNXHD 145 clip in Mocha, it always comes in black. This causes all sorts of issues as I’m forced to use an intermediary for the tracking (usually motion jpeg), and a higher res for the actual comp. Animation codec out of Avid looks like garbage most of the time. What do you use with Avid/PC workflow?
    Also, if I export an exact in/out clip and do the track in mocha, the last tracked frame will always jump as it seems to want to look at the next frame to interpolate the motion. Annoying.
    Does Mocha Pro solve any of these issues?
    Kevin Johnson
    Autodesk Smoke Artist
    FCP Editor
    Washington, DC
    Ross Shain replied 11 years, 8 months ago 3 Members · 2 Replies
  • Michael Szalapski
    December 30, 2014 at 3:03 pm
    You might consider updating. 13.2 has some bug fixes.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Ross Shain
    January 2, 2015 at 7:30 pm
    Hi Kevin,
    I would suggest logging a support case as this does not sound like standard behavior.
    https://www.imagineersystems.com/support/contact-support/
    “1920x1080i clip in 1080 AE comp. Send to Mocha. The surface and adjusttrack zoom window isn’t representative of the area that I am trying. For example, if I’m trying to find the exact corner of an iphone (white bezel and black screen area), the zoom window is nowhere close to there, just showing a blurry white mess. Any sort of fix?”
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
