Activity Forums Adobe After Effects mocha Camera Solve problem
  • mocha Camera Solve problem
    Posted by Nina Tenny on September 4, 2014 at 4:10 pm
    I’m having a problem with a piece of footage I’m tracking in mocha Pro to import into After Effects. The shot is a tricky crane shot over a wide landscape. I’m using the Camera Solve tool to track objects & camera movement.
    The problem I keep having is trying to “solve” the shot. I’ve created about a dozen track layers. When I select 3 or 4 at various depths to “solve”, Mocha tells me that “Camera will be solved only for frames [#] to [#]. Select more layers to get the solution for a wider frame range.”
    AND it won’t solve anything — Solve quality remains at 0%. I’ve tried selecting all my layers, selecting 2, selecting 12 — I keep getting the same message, just for different frame #s. What am I doing wrong? How can I get a camera solve? Thank you!
    Roland R. kahlenberg replied 12 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 6, 2014 at 1:17 am
    Without looking at the footage and your tracking splines, it’s impossible to know what it is that is causing the issue. You’ll need to provide a screen capture of your tracking splines and a low rez view of the footage.
    Cheers
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
