Activity Forums Adobe After Effects Mocha AE Keyframes
  • Mocha AE Keyframes
    Posted by Jake Rose on October 28, 2015 at 10:14 pm
    When I track a shot in Mocha AE with the surface tool on, Mocha will mess up and loose what it’s supposed to follow. So, I stop the auto-track, adjust as needed, then continue. However when I’m finished, it seems my adjustments mess up everything that went before.
    If I create a keyframe at the very end of the shot and make the surface exactly right, than that will mess up the first frame of the shot!!! What gives!!!???????
    Adobe CC, Mocha AE, mov video file
    Jake Rose replied 10 years, 10 months ago 54,134 Members · 3 Replies
  • Jake Rose
    October 28, 2015 at 10:21 pm
    The problem I am describing in completely within Mocha. This is all happening before I go back to AE…unless this “broken” stuff refers to Mocha AE itself.
  • Jake Rose
    October 28, 2015 at 10:40 pm
    Okay, insert string of expletives here: #*&$^#*&$^)#(&#)(@*
  • Jake Rose
    October 28, 2015 at 10:50 pm
    Honestly I am making the shot work right now with the track I got, plus using the Mesh Warp in AE to do some minor adjustments.
    This was working yesterday…I need to get the shot done and I am not that experienced with Mocha so I’ll just make due for now.
    I am doing screen replacement on a laptop.
