Activity › Forums › Adobe After Effects › Mocha AE
  • Posted by Lori Waite on February 1, 2018 at 12:11 am
    I’m tracking a shot using Mocha AE CC. When I export the tracking data – ‘After Effects Corner Pin [supports motion blur]’ ‘Copy to Clipboard’ – and paste the clipboard to my comp in AE, the tracking data is way off. I also tried pasting to a Solid, making it a precomp and transforming the tracking object (a business logo) to the solid using ‘Fit to Comp’ but I get the same results: the tracking data from MOCHA is not transferring accurately to the AE comp. Its the exact same shots – same aspect ratio and frame rate. Any thought as to why this is happening? (The shot’s properties are 2048 x 858, PAR 1, 23.976 FPS .MOV. These properties are exactly the same in both MOCHA and AE comps. )
    Mark Whitney replied 8 years, 7 months ago 2 Members · 3 Replies
  • Mark Whitney
    February 1, 2018 at 3:46 am
    Kinda working blind here, but confirm that the starting frame for both project 7 Mocha are the same & that you’re at the head of the clip when pasting.
  • Lori Waite
    February 1, 2018 at 4:51 pm
    Your comment clued me in that my in and out points for the tracking in Mocha were not at the hds and tls of the whole shot. And I pasted the MOCHA tracking data the hds of the shot, not where the inpoint was on the shot in MOCHA. Thank you for your help, Mark!
  • Mark Whitney
    February 2, 2018 at 3:07 am
    Your quite welcome Lori. It’s quite often the simplest of things that get overlooked.
