Activity › Forums › Adobe After Effects › Mocha Add Key Button???
Posted by Daniel Garriga on April 8, 2011 at 3:25 pmHey all,
This is real frusturating. I am trying to adjust my motion tracking by manually adding keyframes but the “Add Key” button is grayed out! How do I Add Keyframes manually?!Roland R. kahlenberg replied 15 years, 5 months ago 2 Members · 7 Replies -
April 8, 2011 at 3:31 pmSounds like you may have either AutoKey or Uberkey switched on. If both are Off, then select a tangent, this will turn on the Add Key button.
HTH
RoRKAE Training in South East Asia. AE templates for sale and rental. Click here for more
April 8, 2011 at 3:43 pmIt works over here. Why not just switch on Auto Key until you’ve sorted out your issues.
HTH
Daniel Garriga
April 8, 2011 at 3:58 pmI got it but it was keyframes for only the splines not the area I will place my image asset in. How do i manually keyframe the 4 point corner pins?
April 8, 2011 at 4:03 pmHi Daniel, you’re alluding to the Surface. The Surface can’t be keyframed. The Surface simply follows the Shape that is being tracked. If your Surface is not behaving, then the track is insufficiently accurate. You either use the Adjust Track feature or re-track with new settings or shape(s).
HTH
April 8, 2011 at 4:56 pmDon’t forget that a new track region may be the best option instead of Adjust Track. You may also want to use Imagineer System’s COW Forum – https://forums.creativecow.net/imagineer for future related Qs.
Cheers
