Activity › Forums › Maxon Cinema 4D › Mobius strip
  • Mobius strip
    Posted by Kelly Johnson on October 22, 2008 at 3:13 am
    I feel there’s gotta be a way to use a formula attached to a spine and then just extrude it to get a mobius strip?
    Or is there something else?
    I’m on C4D 10
    Kelly Johnson replied 17 years, 11 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    October 22, 2008 at 4:36 am
    There’s a pretty easy way to do it. Use a SweepNURBS and then adjust the rotation spline in the attributes manager so that one point is all the way Y max and the point at the opposite side of the graph is at Y min.
  • Brian Jones
    October 22, 2008 at 6:24 pm
    That would give a full twist, I think. You would need to go Y max (or min) on one side and Y Middle (0.5) on the other side to get the 1/2 twist a mobius needs – it also leaves you with one twisted poly that has to be deleted and replaced by hand.
  • Kelly Johnson
    October 23, 2008 at 7:22 pm
    Thanks to both of you!
