Activity Forums Storage & Archiving Mobile shared editing storage
  • Mobile shared editing storage
    Posted by David Glass on January 6, 2014 at 9:36 pm
    Hello,
    Last year we got to the position (as I’ve read many others on here have) where we needed a shared storage solution for our 5 edit suites, as we couldn’t deal with the multiple hard drives and copying of footage between them all. We eventually went for a 32tb GB Labs Space drive and it revolutionised our workflow and I wonder how we managed without it.
    We have now come across the same issue when we are editing on site away from the Space drive and the quick turnaround of footage from multiple camera teams for press for same day use becomes a slow, painful and sometimes complicated affair.
    There is sadly no way I can justify the purchase of a second Space server and after a lot of searching I still can’t find anything suitable…what do you find works?
    It needs to give the following –
    4tb – 8tb storage (ideally upgradeable in the future)
    RAID operation
    The ability for a minimum of 2 editors to work from the drive simultaneously, ideally 2 editors and 1 DIT ingest machine.
    Ethernet connections – we usually work on a mix of Mac Pro and Retina laptops so Ethernet or a retina compatible alternative
    Footage would usually be Xdcam HD, 50mbps 25fps.
    Some edits would be multicam so fast enough to handle multiple streams would be best and allow for a little headroom
    Editing on FCP7 or adobe CC, after effects CC.
    A budget of around 1-1.5kGBP exc drives
    Hope that’s enough to go on, I keep coming across little companies promising lots (and some do look good) but I would love some real world experience and feedback before I purchase.
    Thanks in advance
    Kevin Rag replied 12 years, 8 months ago 7 Members · 16 Replies
  • 16 Replies
  • Kevin Rag
    January 7, 2014 at 10:53 am
    I’m in the same boat as you. I’m looking for a system where 3 MBPs running FCPs can ingest and share footage on-site, preferably projects too.
    Two options I found were the Editshare Field 2 or the Editshare Ultra. It is a bit expensive but both Avid MCs and FCPs can share media.
    Would like to see what the others suggest. I have to decide wtihin a week’s time.
    What about the Caldigit Supershare? Could be more expensive than the Editshare.
    Kannan Raghavan
    The Big Toad Films Pte. Ltd.
  • David Glass
    January 7, 2014 at 5:44 pm
    I have had a quick look at those systems and i think the Editshare systems look very good but i need to do a bit more digging to find exact prices as most places were POA. They do look a bit ‘over spec’ed’ for what we need. Maybe im being unrealistic with the price (The Space drive was about 15k!) but i was hoping for maybe a 4 or 5 drive mini system. Think Drobo box size but spec’ed for video (i.e. not so slow) Maybe there is not a solution without paying a lot more? Anyone else had any experience with this?
    ….couldnt find a stockist for the Caldigit Supershare but this looks promising. Its on their UK website but once you hit find a reseller im yet to find one, think it may have been superseded?
  • Alex Gerulaitis
    January 7, 2014 at 8:34 pm
    [Kannan Raghavan] “Two options I found were the Editshare Field 2 or the Editshare Ultra. It is a bit expensive but both Avid MCs and FCPs can share media.”
    Have you looked at SNS Evo by any chance? File/volume, Avid bin locking, compatibility with FCP(X) and Adobe CS/CC, some cool things like ShareBrowser (lightweight MAM)… Starts at $7K I believe…
    — Alex Gerulaitis | Systems Engineer | DV411 – Los Angeles, CA
  • Alex Gerulaitis
    January 7, 2014 at 8:39 pm
    Small-Tree GraniteSTOR TitaniumZ-5 is $7.K for 10TB.
    Other than lower cost NAS and SAN boxes from vendors specializing in video (GB Labs, EditShare, SNS, Maxx, etc.) you could look either at DIY or generic NAS from the likes of QNAP, Synology, Thecus.
  • Kevin Rag
    January 8, 2014 at 12:54 am
    Thanks for the suggestions Alex. The Granitstor Titanium Z5 is very interesting. Will look into that.
    Hope you find your solution David.
    Kannan Raghavan
  • Duncan Beattie
    January 8, 2014 at 2:14 pm
    Hi David
    Glad to hear you are so happy with your 32TB unit. We also do a range of portable solutions which will work in the same way. Also with our new V3 you can use workflow tools to move data back from your field unit to your main storage to keep your files safe.
    https://www.gblabs.co.uk/products/Mini_Space/
    Very happy to give you a call to discuss.
    many thanks
    Duncan
    Duncan Beattie
    Global Product Manager
    GB Labs LLP
    duncan (@) gblabs.co.uk
    http://www.gblabs.co.uk
  • Eric Hansen
    January 8, 2014 at 6:57 pm
    I tested the Small Tree TitaniumZ-5 over the summer and it was awesome. It has four 1GbE ports built in. it has a single card slot so you can add more 1GbE or 10GbE ports, or even an SAS card for expansion. It’s about as plug and play as this niche can get. A client of mine bought one for field production for Red Bull events. He uses it almost exactly as you describe.
    You could also look at building a shared system around a Thunderbolt RAID, a Mac Mini, a Thunderbolt 10GbE adapter and a 10GbE switch. More expensive and more parts, but very capable and gives you expansion options.
    You definitely need to raise your budget though. The TZ-5 is about as inexpensive as you can get without going DIY and building your own NAS.
    e
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • Bob Zelin
    January 9, 2014 at 3:26 am
    Hi David –
    while I could say “you should use Brand X” – I am amazed by two things in this post. 1 – you own a GB Labs Space. You know it works. You know they make a portable system. Yet you want to consider “something else”. Why ? Well I know why.
    So, you have been given wonderful advice by many smart people on this forum, mentioning the same brands that always get mentioned. And they are all good companies, and they all work.
    But my unnecessary reply here is not to further recommend a brand, but to denounce a suggestion that you made in one of your posts in this thread. You are NOT going to use a Drobo for this. You are not going to spend $1500 and get a working solution. You will spend the correct amount of money, and get something that works, and not some piece of crap that was never designed to be a shared storage system, and try to “jury rig” it so you can avoid spending the correct amount. You already know that GB Labs makes a great product. You have been given wonderful advice in this thread on multiple brands that will all work for you – all wonderful companies, with wonderful support. But I guess I am getting hypersensitive (and have been so for quite some time), about people that have only one concern – “what is the LEAST amount of money that I can spend to get this to work”. You are a pro – buy professional equipment that will do the job, not some piece of crap.
    Bob Zelin
    ps – thunderbolt networking as of 1/8/2014 DOES NOT WORK, so you can’t get a Mac mini, or even a new Mac Pro, rig up some Tbolt 2 laptops with Thunderbolt cables, and have shared storage. It doesn’t work.
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Kevin Rag
    January 9, 2014 at 5:03 am
    Hi Eric. I’m still waiting for quotes from Small Tree, Edit share, SNS, and GB Labs.
    With the Small Tree TitaniumZ-5, you just hook up the MBPs with a ethernet cable, right?
    Cheers
    Kannan Raghavan
  • Kevin Rag
    January 9, 2014 at 5:15 am
    Hi Duncan,
    The Mini looks great. Can I hook up three MacBook Pros to this with just ethernet cables?
    Two of the MBPs would be ingesting and editing simultaneously. I work in ProRes 422, either 1080i50 or 1080i60. Would I have enough throughput for all three clients?
    Kannan Raghavan
