Activity › Forums › Lighting Design › mobile lighting setup for interviews
Tyler McClure replied 4 years, 7 months ago 7 Members · 11 Replies
Tyler McClure
January 23, 2022 at 2:18 pmAlthough this is an old post, I’m hopeful this may help others in the future. 😀
I recently did a review on a portable LED video light here: https://youtu.be/CKsEonWBQkQ
The Smart Electrician 1,000 lumen rechargeable LED video light has two dimmable modes: 1,000 lumens or 5,000 lumens. The light is daylight balanced to 5,000 degrees Kelvin, with a CRI of <78. It contains a micro USB to USB-A charging cable to charge or power on the go. The rechargeable battery is rated at 5,000mAh capacity. The light is currently priced at $16 at Menards.
If you purchase the light from Menards, consider adding a 5,000mAh USB battery bank for an additional $4.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
