https://www.tech-faq.com/mms.html
There are many challenges that exist with MMS:
Adaptation of multimedia content: There may be a difference in the compatibility of multimedia content for different brands of cell phones. If the network operator is supporting your content adaptation – you can enjoy compatibility with more networks and vice versa.
Cell phone configuration: Multimedia Messaging Service requires some parameters to be correctly placed in you handset. Sometimes, due to poor configuration, you may not receive messages.
It depends on the phone and carrier.
Telestream Episode 5.3.2 had many categories of presets
Circuit Switched 3GGP
Circuit Switched 3GGP R5
Circuit Switched 3GGP2
GPRS 3GPP
GPRS 3GPP R5
GPRS 3GPP2
GPRS 3GPP2 EVRC Audio
UMTS 3GPP
UMTS 3GPP R5
UMTS 3GPP2
And each of the above has Download and Streaming subfolders with several presets for each.
That Squeeze preset looks closest to UMTS.
What if you need AMR or EVRC audio instead of AAC for example?
You need to know the target to develop the settings and what works on one phone may not work on another.
