M&M Candy Shape??
Posted by David Distinti on June 4, 2009 at 4:03 pmI need to create an object shaped like an M&M candy.
How do I go about doing this. I’m sure this a no brainer
but I simply can’t find the correct setting to accomplish this.I have InvigPro with AE-CS4 (WinXP).
Regards,
DaveEdward Wu replied 17 years, 2 months ago 3 Members · 4 Replies -
Edward Wu
June 4, 2009 at 9:45 pmHi David,
To pull do this, you will have to use custom edges to get the look you wanted. First, you will need to go into the “Documents (Mac) / My Documents (Win) > Zaxwerks > 3D Invigorator > Custom Edges” and open the Edge Examples.ai file. In the Edge Examples file, draw a curve in a new layer. Name the layer “M&M”.
The curve should look similar to the example picture below:
Once you completed drawing the custom edge, save the Illustrator file, and create a new Illustrator file.
In the new Illustrator file, draw a tiny circle (which we will use to apply the custom edge on), and save the file “tiny circle.ai” without compression.
Next, open ProAnimator, and use the “Open Illustrator File” command to open the “tiny circle.ai” file. Then, in the Object tab to the right, select the bevel “M&M”, and you will be able to get the M&M shape. To make the shape smooth, turn the Object Faceting settings to to “0.05” or “0.01”.
After you adjusted all the settings, you should be able to get the M&M shapes shown below:
If you need more information on Custom Edges, please visit our Goodies page provided below:
https://zaxwerks.com/goodies/custom_edges.shtmlBest,
Edward -
Serge Hamad
June 5, 2009 at 2:55 amHi,
Learning about custom edges is very important if you want to master Invigorator/ProAnimator. You may want to check out the “Custom Edges” tutorial here at the Cow.
Another very useful feature is the Scale option. (Located in the Stats Menu)
If you create a sphere primitive, open the Stats menu and alter the (Z) Scale to (0.3 or so)you will get a perfect M&M shape with two clicks.
Salut,
SergeInvigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
David Distinti
June 5, 2009 at 5:41 amThanks for the help guys. I really appreciate it!
Regards,
Dave
