Activity Forums Adobe Premiere Pro MJPEG workflow advice on a mac…
  • MJPEG workflow advice on a mac…
    Posted by Mike Albertini on July 12, 2011 at 9:32 pm
    Excuse my ignorance but I’m still training to be an editor using final cut studio and media composer etc but was offered an edit assistant gig using premiere pro today… I decided to take it as i have the software and knew it was similar to fcp…I’ve had a play around just now and it is pretty similar to fcp so no problem there…
    Anyway, on Friday I’m going to be given a ton of footage to cut, organise and export using premiere which is no problem except that the guy has specified that I keep everything in the mjpeg format…it will arrive in mjpeg and he has specified he wants it exported directly from premiere with no extra compression – as mjpeg…he says he’s done this in premiere with this footage himself…that he keeps working and queues up the sequences for export…think he was on a pc whereas im on a mac…I’ve played around with premiere and can see you can queue to export a sequence…ive tested some of my own 720p footage and exported it using FILE>EXPORT>MEDIA>QUEUE and ticked match sequence settings and this creates an mpeg file which VLC will play…sounds like the workflow he mentioned and works fine…
    I’m just wondering what preset i use for the sequence when i import these mjpeg clips and what preset i use when i export them…i cant see an mjpeg one in here…
    Any advice would be much appreciated…
    Mike
    Jeff Greenberg replied 15 years, 1 month ago 2 Members · 3 Replies
  • Mike Albertini
    July 13, 2011 at 6:43 pm
    no worries….just found the New item icon in project pane to create sequence settings from clip settings…and then just tick match sequence settings on export…
  • Mike Albertini
    July 13, 2011 at 6:59 pm
    although ‘match sequence settings’ only outputs mpegs no matter what type of footage im exporting…how do i export a file as mjpeg from premiere?
    Mike
  • Jeff Greenberg
    August 2, 2011 at 4:35 pm
    You need to change the output codec in QuickTime inside of Premiere Pro
    Export Media
    Format QuickTime
    Video tab choose Video Codec – MJPEG A (or B) and play with the given settings.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
