Activity › Forums › Adobe Premiere Pro › mixing widescreen and standard ntsc-ASAP please
  • mixing widescreen and standard ntsc-ASAP please
    Posted by Raine Parrish on November 8, 2005 at 11:04 pm
    hello-
    i’m creating a demo reel- but my footage is a mix of both dvcam widescreen and older footage- which is standard.
    using premiere 6.5 for the cut.
    is it possible to mix the two on the timeline- and if so, how- when i capture the widescreen- naturally i am using the widescreen capture setting.
    but then, for the standard- i use that setting.
    i am assuming i have to do seperate captures- then import the footage into a new project?
    i can select clips from the standard footage that will permit me to lay in the widescreen masking bars- but how do i set the setting to allow for both formats on the timeline with the edit windows?
    thanks much
    rp
    Tim Kurkoski replied 20 years, 10 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    November 9, 2005 at 6:48 pm
    You can capture both formats in the same project. The problems all occur when you put them in the timeline, but it’s really not that big of a deal.
    Whether you’re using a widescreen timeline or a standard timeline, one of your types of clips are going to be out of proportion. You’ll probably need to scale (in 6.5, use the Distort > Transform effect, not the Motion properties) at least one dimension to fit within the dimensions of your project.
