Activity › Forums › Adobe After Effects Expressions › mixing two movies
mixing two movies
Posted by Bender on February 12, 2006 at 4:30 pmhi guys
is it possible to mix two or more movies … at the end i wanna have
movie1_frame1
movie2_frame2
movie1_frame3
movie2_frame4and so and so on!
anybody got a clue?
thanks so much!
best
florianRyan Hill replied 20 years, 7 months ago 4 Members · 6 Replies -
Chris Smith
February 12, 2006 at 5:30 pmPut one layer on top of the other. On the top layer use your favorite method of making the opacity turn on and off every other frame. Like a simple expression.
Or create a 2 frame comp. One frame is white, the other frame is black. Render this out and bring it back in. Set it to loop. Use it as a luma matte on the top layer.
Chris Smith
https://www.sugarfilmproduction.com -
Mylenium
February 12, 2006 at 5:31 pmPut them in one comp and animate the opacity of the top layer. create a simple cycle that covers 2 frames and then use a “loopOut(“cycle”,0) expression. Turn off interpolation on the keyframes. another option might be using the strobe effect on the top layer with the “make layer transparent” option.
Mylenium
[Pour Myl
Ryan Hill
February 12, 2006 at 9:20 pmI would apply an expression to the opacity property of the top video. Something like:
time%2 -
Bender
February 12, 2006 at 9:45 pmthanks so much for your quick help…all of your recommendations worked great! but what if i want to mix 3 movies???
i want to create a scribble effect, where each picture is a bit different from the other one…im sure you know what i mean!
so far i discovered that i need at least 3 different movies…otherwise it looks toooo jumpy!
cheers guys
Ryan Hill
February 12, 2006 at 10:17 pmchange to mod 3 instead of mod 2, and add a greater than
First layer:
(time%3>1)*100Second layer:
(time%3>0)*100Also, if you want to reduce the frequency of the change, you can do something like this:
((time/2)%2>1)*100
to divide the frequency in half.
