Activity Forums Avid Media Composer Mixing Resolutions in a Timeline
  • Mixing Resolutions in a Timeline
    Posted by Matt Burrows on October 3, 2009 at 3:25 am
    So… how do you deal with the different field dominance characteristics of HD and SD (upper field/lower field) when you mix HD and SD resolutions on a timeline? I’ve never understood this and it’s actually causing me a problem now that I have a job w/mixed resolutions. When I export in order to burn a dvd, I can see that there is a field dominance mismatch on either the HD or SD (depending on the setting I choose when I export). What’s the answer? Certainly there’s a work around because mixing resolutions is one of Avid’s big marketing points.
    The only woman I’m pimping is sweet lady propane! And I’m tricking her out all over this town.
    Matt Burrows replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
