Activity › Forums › Apple Final Cut Pro Legacy › Mixing ProRes 422 & 4444 in same sequence?
Posted by Ross Whitney on January 25, 2010 at 12:26 amWould mixing these two codec family members in the same project produce RT complications? I’d like to use 4444 only when an alpha channel’s needed, and 422 for everything else.
Will Griffith replied 16 years, 8 months ago 6 Members · 6 Replies -
Rafael Amador
January 25, 2010 at 4:26 amHi Ross,
I haven’t tried that yet because I’m still with FC6,but, instead of asking I would make a simple test with my own system.
Cheers,
rafael -
John Pale
January 25, 2010 at 5:41 amNo problem. ProRes 444 with alpha plays in real time in all flavors of ProRes sequences on my system.
Gary Adcock
January 25, 2010 at 1:51 pm[Ross Whitney] “Would mixing these two codec family members in the same project produce RT complications? I’d like to use 4444 only when an alpha channel’s needed, and 422 for everything else. “
No, that is how the codec was designed, so that you could use 4444 when necessary then ditch the rest.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://blogs.creativecow.net/garyadcock
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Will Griffith
January 25, 2010 at 5:34 pm2K and 1080p seem to be fine with graded ProRes 4444 Red originated footage and older ProRes b-roll
John Fishback
January 26, 2010 at 9:51 pmHow should Compressor be set in Seq Settings?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Will Griffith
January 26, 2010 at 10:57 pmset it to the codec that matches the largest amount of footage that will be in your timeline
