Activity Forums DSLR Video mixing Pro ress 4444 and Pro res 422 (LT)
  • mixing Pro ress 4444 and Pro res 422 (LT)
    Posted by Tony Gomez on March 30, 2011 at 2:28 am
    Just notice I imported all my files from my D7 in Apple pro res 422 (LT) and in 4444.. would this be a problem.. it’s HD 1920×1080.. Final Cut pro 7.. anyone?
    Shane Ross replied 15 years, 5 months ago 3 Members · 2 Replies
  • Noah Kadner
    March 30, 2011 at 4:46 am
    Visually not so much but 4444 is quite a higher bitrate that is way overkill for 7D footage. Going to require a lot more and faster hard drives to edit. I’d go back and re-compress to ProResHQ if it’s a lot of footage. If it’s a little you’ll probably be fine.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
  • Shane Ross
    March 30, 2011 at 6:51 pm
    NOt only is 444 overkill, it damages the image. Any time someone transcodes 5D or 7D to 444, my luminence hits a ceiling of 98 when i color correct. It won’t go above. And the floor is 0 IRE. This might be fine for broadcast work, but not everything is broadcast…and when color correcting, you want to push beyond those limits anyway.
    Shane
