Activity Forums Adobe After Effects Mixing Particle Illu and AE
  • Mixing Particle Illu and AE
    Posted by Mbevilacqua on May 24, 2007 at 5:46 am
    Hi, I’m novice AE and PI user so this will probably be a simple one!
    After seeing the tutorial to fix tracking info from AE to PI I decided to try it. Position data worked like a charm (thanks Cow!) but I face a new problem now: transfer modes!
    At PI effect looks great against black bg, I render to TIFF with alpha and when compositing in AE colors loose strenght and it simply doesn’t look good. I think I understand the problem, basically in PI the semi-transparent bits are “added” to the black bg and this adds up strength to the colour, when “removing” that black bg (which now in AE if my comp bg) the effects lack that black component and seems to ghost out.
    Although I think this is the problem I have not found an easy way to fix this, too new to AE I guess…
    Any help?
    Thank you in advance.
    Mbevilacqua replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
